big problem with getting 302 to fire
Old Mar 4, 2007 | 06:41 PM
rowdy78's Avatar
rowdy78
Question big problem with getting 302 to fire
check this out guys. my brother has a 89 302 fuel injected in a bronco. The motor was running. we got into a simple discussion that all of us know. Where cylinders 1234 and 5678 are. obviously 1234 is on passanger side. he goes home and changes his firing order on his motor to 12345678 being criss-crossed. Wont fire. changes it back the way he had it with it running. wont fire. jumped timing right... no. we checked his chain. lines right up. He's on the compression stroke. getting fire...getting fuel. should fire right. we're scratching our heads. any suggestions
Old Mar 5, 2007 | 10:36 AM
Kemicalburns's Avatar
Kemicalburns
get a haynes manual in put to proper firing order
Old Mar 10, 2007 | 08:02 PM
rowdy78's Avatar
rowdy78
I call my brother to see how things are going and to tell him to check his firing order one more time and i say to him make sure you going counterclockwise and he says counterclockwise? S**t i'm all clockwise out there. Changes it and fires right up. goes to show you we sometimes skip the most simplest things. thanks
04redstroker
23
Sep 10, 2013 11:51 AM
Nally427
Jun 9, 2013 09:07 PM
CPTMidnight
May 31, 2011 10:08 PM
Jag Red 54
Jan 6, 2010 08:57 PM
DT 466Man
Sep 6, 2004 09:11 PM
