Optimum fuel Pressure for 24's
Old Mar 5, 2007 | 12:47 PM
nastruk95's Avatar
nastruk95
I have a stock 5.0 truck motor with speed dens. The motor was bought seperate. My question is that it came with reddish-orange fuel injectors, I assume these are 24lb and that stock was 19lb, I pretty sure this is right. I'd like to keep the 24's but was wondering if anyone has any experience with what a good starting fuel pressure would be with the larger injectors on a near stock motor. It runs quite rich now. Thank you for any input.
Old Mar 5, 2007 | 01:35 PM
garsten's Avatar
garsten
not so long ago, i assumed that the 30# injectors i bought off ebay were 30# injectors. after trying several different maf meters, i finally decided to read the part number off the injector and figured out they were 19# (red in color) injectors ford used on trucks in mexico.
knowing what you have is the first step. cheers, garsten
Old Mar 5, 2007 | 05:04 PM
Kemicalburns's Avatar
Kemicalburns
your stock efi will not support 24lb injectors. and adjusting the fuel pressure is not good idea. save them for a latter time
Old Mar 5, 2007 | 05:24 PM
nastruk95's Avatar
nastruk95
I plan for more upgrades. For now though, wont lowering the pressure be equivalent to a lower injector number. I've always found adjustable fuel press regulators a great way to get the peak performance from modifications.
Old Mar 5, 2007 | 07:50 PM
EPNCSU2006's Avatar
EPNCSU2006
Yes, less pressure means less flow, but it isn't a linear relationship. Here's a calculator I found online that relates pressure to flow (stock fuel pressure is around 3 bar or 44-45 psi):
http://www.witchhunter.com/injectorcalc1.php4
scroll to the bottom for pressure modification
Old Mar 6, 2007 | 09:37 AM
Kemicalburns
you cant think mustang mods for a truck. at least not a sd truck
Old Mar 6, 2007 | 10:12 AM
nastruk95's Avatar
nastruk95
Thank you for the help, I'm going to go ahead and find 19's. The MAP Sensor is also mia so hopefully replacing and hooking that up will help also.
Intimnasc
Mar 22, 2013 11:32 AM
hescbr600
May 16, 2006 08:33 PM
mauicruza
Jan 24, 2006 05:27 PM
351M
Jul 19, 2005 10:08 PM
smurray
Mar 13, 2005 10:39 AM
