Timing Chain Replacement...
Old Mar 5, 2007 | 12:35 AM
ReverendMachine's Avatar
ReverendMachine
Alright guys. Im ready to install a new timing chain any advice on the Do's and Dont's would be really good to know right now lol. Thanks for your input.-Rev
Specs are:
85' 302 HO In my 72' F-100
1-3-7-2-6-5-4-8
Old Mar 9, 2007 | 03:32 PM
ReverendMachine
Ok Here is a Shot Of The New Timing Chain In... Someone told me that the cam gear and crank gear should line-up somehow... Vertically or pionting ar each other?? Here are the pics
Old Mar 9, 2007 | 11:52 PM
baddad457's Avatar
baddad457
That's a NEW set? If it is, better send it back. That's way too much chain slack for a new set. Go get a Cloyes roller set for a late model 5.0. Less than $20 at O'Reillys
Old Mar 10, 2007 | 05:14 AM
HemiEater's Avatar
HemiEater
there is a mark on both gears
Old Mar 10, 2007 | 01:44 PM
ReverendMachine
Much Aprieciated Hemi. You have no idea how much this helps thanks guys.
Old Mar 11, 2007 | 10:36 AM
hatch_1989's Avatar
hatch_1989
Baddad457:
I had the same problem with a replacement timing chain set for a 92 302. The extra slack makes me wonder whether the database incorrectly references a 351 part number instead of the 302 number. I do not recall for sure which brand I had the problem with nor what brand was correct. I do believe both came from O'Reilleys.
Old Mar 11, 2007 | 11:17 AM
HemiEater's Avatar
HemiEater
it should not matter a 351W is the same.....
Old Mar 11, 2007 | 11:27 AM
baddad457's Avatar
baddad457
Ditto, the 302 and 351W have the same crank to cam spacing. Possibly a 351C set could fit? I don't know as I've never tried that.
Old Mar 12, 2007 | 10:26 AM
hatch_1989's Avatar
hatch_1989
All I remember is the 1st timing set was not right. As I recall the cam sprocket was different and the chain had too much slack.
DieselCamper
Nov 3, 2016 11:41 PM
brent1204
1983 - 2012 Ranger & B-Series
Jul 6, 2015 08:18 PM
ERF
Oct 22, 2007 12:13 PM
mikemic
Jan 11, 2006 03:40 PM
sillyp
34
Oct 4, 2004 02:29 PM
