serpentine swap
Old May 4, 2009 | 05:29 PM
tex4431's Avatar
tex4431
serpentine swap
I have a 351W in my '72 I want to put a serpentine pullys setup on it. Will my factory alt. work with the a serp. pully on it? If no,what do I need to run a serp. system?
Old May 4, 2009 | 06:41 PM
93F22A6's Avatar
93F22A6
It might, I would just up grade to the alt that they used with the setup. If your getting in from the junkyard just grab the alt with it.
Old May 4, 2009 | 06:50 PM
70torino429's Avatar
70torino429
i used all the aluminum brackets and mounts from my 91 truck when i swapped the serpentine setup on my older engine, bolted right up, looks better, and is lighter
Old May 4, 2009 | 06:52 PM
tex4431's Avatar
tex4431
The wiring is different on the newer alt.
Old May 4, 2009 | 06:56 PM
tex4431's Avatar
tex4431
What alt. did you use? ote=70torino429;7463415]i used all the aluminum brackets and mounts from my 91 truck when i swapped the serpentine setup on my older engine, bolted right up, looks better, and is lighter[/quote]
Old May 4, 2009 | 06:59 PM
70torino429
i used the 91 alternator, but as far as i know you shouldnt have any problem using your old alternator on the newer brackets, since the mounting points are still the same as far as i know.
kyle j
Feb 5, 2017 06:43 PM
kyle j
43
Dec 27, 2016 08:12 PM
hpcbmw
Aug 29, 2015 08:46 AM
BigSix1
Oct 10, 2008 08:14 AM
DennyB
Feb 8, 2007 10:29 AM
