351w heads
Old May 6, 2009 | 10:44 AM
fordrules577's Avatar
fordrules577
351w heads
I was trying to decide wheather to go with aluminum heads or cast iorn. They are going on a daily driver and i was worryed about the long term strength of alumunmum heads. I want some second oppinions.
Old May 6, 2009 | 12:38 PM
Kemicalburns's Avatar
Kemicalburns
what else is done to the motor? besides a DD what else is the vehicle used for? 2wd or
4wd?
Old May 6, 2009 | 08:41 PM
fordrules577
Its going to be used off road haulin wood and other stuff. There aint much done to the motor yet. I want to decide what i am going to do before i start buying anything especially if im puting on different heads.
Old May 7, 2009 | 09:23 AM
Conanski's Avatar
Conanski
The big benefits of aluminum are lighter weight and the ability to run higher compression. The downsides are corrosion from dissimilar metals and less durability under detonation. There are some manufacturers offering iron and aluminum heads that are identical except for the materail, so it's not necessary to to buy aluminum to get performance. I selsected iron heads for my 351 because it is a truck motor, saving a little weight on the motor really doesn't mater, and the iron heads were $250 cheaper than the aluminim versions.
Old May 7, 2009 | 09:43 AM
fordrules577
thats what i was thinkin. What iron heads would you reccomend
Mister_King
Jan 26, 2015 05:32 PM
77custom408
Oct 24, 2012 08:59 AM
v8xploder
Dec 26, 2006 06:47 AM
351fairlane
18
Apr 14, 2005 11:31 AM
sledhead1
Mar 24, 2001 02:48 PM
