Engine Stumbles on Turns
Old May 2, 2009 | 08:55 PM
Sport45's Avatar
Sport45
Our '83 F-100 w/ 302 and AOD will sumble/hesitate when going around a corner. I though it might be the fuel level in the carb bowl, but that looks to be correct. Any other ideas? If it is the fuel level, should I adjust it slightly higher or lower in a first trial?
Thanks!
Old May 3, 2009 | 12:37 PM
jerg_064's Avatar
jerg_064
Do you let out of the gas on corners? And is it happening when coming to stops as well?
Could be the timing. just a thought.
BTW, I like the before and after pix. Nice paint man.
Old May 3, 2009 | 01:19 PM
cjohnsd69's Avatar
cjohnsd69
Hey ! I had the same problems with my trk - I had to have the throttle body & mass air sensor replaced....they also did a fuel injector flush....Problem fixed....
Old May 3, 2009 | 01:22 PM
jerg_064's Avatar
jerg_064
Sorry dude, but read his post! He's carbed.
Old May 4, 2009 | 03:47 AM
Sport45's Avatar
Sport45
Thanks for the replies. I haven't noticed the stumble coming to stops as it would be coasting anyway. It's more as you try to accelerate coming out of a turn after coasting into it with the brakes applied. Taking off from a stop generally isn't a problem.
jerkypants
Feb 4, 2012 10:52 AM
429poweredf350
Apr 20, 2011 03:10 PM
captsteve67
Jan 13, 2010 07:14 PM
paintdl
May 7, 2007 09:47 PM
