Carb Flood / Stumped
Old Oct 16, 2009 | 05:17 PM
StrawBoss23's Avatar
StrawBoss23
90-E350 / 86-300 motor / Duraspark 2 Dizzy / chev Module.
I have fuel slowly building up on my intake floor, This was a problem when it had the feedback carb, so i bone yarded a carter yf carb out of a 78 van soaked it and rebuilt it, kit and new float, Still a problem, Pulled it a dozen times and tried a bunch of float and metering rod settings, no luck.
So I got a new intake and exhaust manifolds and had Randy at RH Carb / Portland build me an 82/ non feedback. Still an issue. it sat for a month and ran great for a day or so, but then starts missing and boggin off the line, Fuel building up inside the manifold, milage is about 8...
New carb to manifold gasket
New Mech fuel pump
3 times replaced fuel filter
Fuel pressure is at 7lbs
All vacuum lines replaced.
Motor has been rebuilt 30k ago, compression in the high 160's across the board...
At a lost, any help is appreciated.
Thanks
Old Oct 16, 2009 | 05:46 PM
JimsRebel's Avatar
JimsRebel
What Fuel Pressure do you have at the carb???
What Fuel Pump are you using. Just and engine driven pump or the pump in the tank???
Jim
Old Oct 16, 2009 | 05:50 PM
JimsRebel's Avatar
JimsRebel
Sorry, didnt read the whole post before I hit reply...
Napa sells a inline fuel pressure regulator, I would try 3-4 PSI at the carb.
Jim
Old Oct 16, 2009 | 06:22 PM
JimsRebel's Avatar
JimsRebel
Spectre Industries 2517 - Spectre Fuel Pressure Regulators... $21.95
Fuel Pressure Regulator, Steel, Chrome Plated, 1-5 1/2 psi, for 1/4 in., 5/16 in., 3/8 in. Lines, Universal
Spectre Industries 2517 - Spectre Fuel Pressure Regulators - Overview - SummitRacing.com
Napa/Balkamp # 730-2367, 1-6 lbs, chrome with adjustable dial for 5/16 fuel line.
also try ebay
Old Oct 17, 2009 | 01:14 AM
StrawBoss23
Jim,
Thanks for the reply,
Didn't think 7 lbs. was enough to blow by,
But I will give it a go.
Thanks Again,
Geof
mkhmann
Feb 22, 2017 01:37 PM
Mdc9966
15
Nov 12, 2015 11:51 AM
swolh
27
Feb 8, 2015 10:45 AM
darinbrooks
Feb 14, 2011 03:53 PM
baverwolf
20
May 7, 2010 09:59 AM
