302 Measurements
Old Apr 13, 2007 | 09:56 PM
Jet-Lee's Avatar
Jet-Lee
302 Measurements
I think I put the original thread in the wrong forum. If someone could delete it, I'd appreciate it.
<TABLE><TBODY><TR><TD vAlign=top width="100%">I've got a 71 and a 72 both E-100's. I'm wanting to swap the 72's 302 and C4 into another vehicle. I'm wondering a couple key pieces of information on the motor mount locations so I can finish the pre-fab work before the vans get here.
1. How far apart are the mount points(centers) on the 302 block?
2. What angle are they at? (not necessarily pertinent)
3. How far(vertical/plumb) from the bottom of the oil pan to the mount points(centers) on the block?
4. How far from the front of the block to the mount points(centers)?
Thanks guys!
</TD></TR></TBODY></TABLE>
Old Apr 14, 2007 | 05:42 AM
HemiEater's Avatar
HemiEater
pull it out and measure it......
Old Apr 14, 2007 | 07:38 AM
Jet-Lee's Avatar
Jet-Lee
I don't have them yet, they're being shipped from california 1700 miles away.
Old Apr 14, 2007 | 05:29 PM
petes79f150's Avatar
petes79f150
Just happen to have a bare '70 block on the stand fresh out of the machine shop. Now, these numbers were taken with a straight edge and tape, so while they're not to the .xxxx", they're very close.
1. 7" center to center of the bolt holes (horizontally front to back), 13 1/8" c-c horizontally across the block.
2. The motor mount bosses are machined parallel to the pan rail,
3. 1 5/8" from the pan rail up to the mount bosses.
4. Now, the mount bosses are offset from side to side, with the driver side farther back from the front of the motor by an inch-
D. side 5 3/8" - 12 3/8"
P. side 4 3/8 - 11 3/8"
Hope this helps.
Pete
Old Apr 14, 2007 | 05:34 PM
Jet-Lee's Avatar
Jet-Lee
That's what I was looking for, thank you sir!
Old Apr 14, 2007 | 05:52 PM
petes79f150
You are welcome- and welcome to FTE!
Pete
Old Apr 14, 2007 | 05:56 PM
Jet-Lee's Avatar
Jet-Lee
Thanks for the welcome.
You and I are about 2 hours from each other. I'm in Rogers, AR moving to Tulsa after Christmas.
Old Apr 14, 2007 | 05:58 PM
HemiEater's Avatar
HemiEater
I would go measure a junk car or truck with the motor and trans removed. easy to measure all the distances between the mounts......
Old Apr 14, 2007 | 06:00 PM
Jet-Lee's Avatar
Jet-Lee
Great suggestion. My buddy has a couple pickups at his place I could measure.
Are the mounts for a 351W any different?
Old Apr 15, 2007 | 02:31 AM
darrin1999's Avatar
darrin1999
mounts are the same, but the block is wider through the top on the 351w, thats why it wont fit my maverick without modifications
Old Apr 16, 2007 | 02:12 PM
Jet-Lee's Avatar
Jet-Lee
Well, I appreciate the help, guys!
I'm working on fabbing up the mounts to swap my '72 302 and C4 into my 1999 Ford Escort LX. Make it a little RWD ground pounder while using the '71 E-100 (healthy 302) as my daily.
I get plenty of criticism, but I don't care. Someone pioneered the 302 into the Focus, I want to do it to my Escort.
Old Apr 16, 2007 | 05:32 PM
6CylBill's Avatar
6CylBill
A focus with a 302? I have but two words to say to that. Holy Ballz.
Old Apr 16, 2007 | 08:53 PM
petes79f150
Should be fun. I've been threatening to shoehorn a 302 into an old Geo my wife used to drive. I mean, it's just sitting there, taking up space, right?
Old Apr 16, 2007 | 09:44 PM
6CylBill's Avatar
6CylBill
My mom used to lay rubber with a little 3 cyl Geo. I hate those things..
But, once again. Holy ballz!
Old Apr 16, 2007 | 10:34 PM
Jet-Lee's Avatar
Jet-Lee
351/C4 Focus
