Old Apr 8, 2007 | 08:39 PM
mrflip2's Avatar
mrflip2
Hi
I have a 73 ford 302 in my boat with a holley 2300. Ive got it running after a 12 year hiatus. Rebuilt heads new rings Didn't bore out cyl due to still seeing x marks on walls. I can't get it to idle properly.
I set the timing at 10 degrees btdc Points set to dwell specs still cant get to idle at 700 rpm if I turn up the idle to 1100 rpm it runs good
Any ideas? I've racked my brain so any ideas might help
Old Apr 8, 2007 | 10:16 PM
LxMan1's Avatar
LxMan1
Sounds like either a vacuum leak or something clogged in the idle circuit of the carb.
