302 vibration
Old Apr 11, 2007 | 07:19 PM
hiball3985's Avatar
hiball3985
302 vibration
this is an early 302, the engine was balanced when built, but we had to change the flywheel, now theres a vibration at about 2000 rpm, if I take the old flywheel to the balance shop can they match the new one to the same balance, thought I would ask here before going and have the guy look at me like I'm crazy..thanks
Old Apr 11, 2007 | 07:43 PM
HemiEater's Avatar
HemiEater
is the new flywheel the same balance 28oz?.....
when they balanced it did they weld weight to the flywheel and balancer?..if so you should have gotten a balance sheet so you can get the new one matched....when I did the clevor they wanted to weld on the flywheel I said no put it on the crank so I can change flywheels with out any problems.
You might just have a 50oz flywheel on there.....
Old Apr 11, 2007 | 08:32 PM
hiball3985's Avatar
hiball3985
yes the new wheel is 28oz..its an aftermarket steel billet..I asumed it was balanced..maybe not?? and there was no welding on the flywheel or balancer(Fordmotorsport with 280z bolted on weight) when originaly done
Old Apr 12, 2007 | 05:12 AM
HemiEater's Avatar
HemiEater
hows the clutch...and pressure plate?
why the new flywheel?
sorry for all the ??? hard to do anything miles away.....
Old Apr 12, 2007 | 08:27 AM
hiball3985's Avatar
hiball3985
the flywheel was surfaced when we built the engine about 3 yrs ago...my son tore up the clutch from racing it all the time and it scored the flywheel bad enough that we didn't want to surface it again..so we bought the new flywheel and clutch..at this point I'm just going to pull the trans remove the clutch and test it for vibration and then remove the flywheel and try another one I have and see what happens unless you have another suggetion...thanks for your help
Old Apr 12, 2007 | 02:54 PM
HemiEater's Avatar
HemiEater
pull the pressure plate and run it see if it still dose it.......
Old Apr 12, 2007 | 03:40 PM
hiball3985's Avatar
hiball3985
thats where I'll start..these 60 year old bones don't fell like doing it..thanks for your time
Old Apr 12, 2007 | 03:51 PM
HemiEater's Avatar
HemiEater
.........lol.
how was the pilot bearing when you changed the flywheel? If it's bad the clutch plate wont center it self......just a thought...
run it with the clucth to the floor and see if it still happens........
Old Apr 12, 2007 | 03:55 PM
hiball3985's Avatar
hiball3985
.........lol.
new pilot bearing (not bushing) ran the clutch to the floor, didn't help so its not the plate
Old Apr 12, 2007 | 04:03 PM
HemiEater's Avatar
HemiEater
think there is a chance you get a 50oz flywheel
Old Apr 12, 2007 | 04:06 PM
hiball3985's Avatar
hiball3985
I think we got it right..it was nuetral balance with either a 50 or 28 to bolt on
Old Apr 12, 2007 | 04:13 PM
HemiEater's Avatar
HemiEater
so the worn out flywheel had a bolt on weight......?
if so did you reuse that weight..?
think they might have removed weight from it when they balanced it..?
Old Apr 12, 2007 | 04:19 PM
hiball3985's Avatar
hiball3985
no, the original flywheel didn't have a weight, it was just a stock 28oz, the new one has the bolt on weight...when I get it apart I'm going to try another stock wheel I have, we didn't use it becuase its for a 10 in clutch and we have been using an 11, but if it works I'll get a new 10in clutch for it
Old Apr 12, 2007 | 04:21 PM
HemiEater's Avatar
HemiEater
I'm just thinking........well trying anyways....lol
Old Apr 12, 2007 | 04:22 PM
HemiEater's Avatar
HemiEater
never liked those bolt on deals ... the balancer on the clevor has a bolt on weight but i had it when they balanced it. Hope it holds up.........
