Odd sound while holding speed.
Old Apr 11, 2007 | 12:33 AM
wintremute's Avatar
wintremute
Carbed 302 in a 77 F150...
At 50 or above, holding a steady speed, I have a noise from the engine. Not a grinding noise, I would call it a cavitating sound. When accellerating or decelerating it does not make this sound, only when holding a steady speed (2.79 gears, 225/60/15 tires if this helps). It seems like it might be that the timing chain stretched out and is rubbing the timing cover, but i'm not sure. Would it stretch that much and not jump? Other than this it runs great and gets 16 mpg, which I am very happy with being that it has 240K on it. Original timing chain BTW.
Old Apr 11, 2007 | 01:10 AM
LxMan1's Avatar
LxMan1
Does it do it if you just hold the rpms up in park?
Old Apr 11, 2007 | 01:28 AM
wintremute's Avatar
wintremute
Yes it does
Old Apr 12, 2007 | 05:27 AM
HemiEater's Avatar
HemiEater
water pump......
Old Apr 12, 2007 | 12:28 PM
wintremute's Avatar
wintremute
I thought so too, but I just replaced it and the sound is still there.
Old Apr 12, 2007 | 05:45 PM
HemiEater's Avatar
HemiEater
I had a new distr do that, took about 1000 miles before the bushings went bad....I replaced the distr and the went away.
also check the belt tentioner (sp) alt and ps pump use a long screwdriver..put it against your ear and then hold it on the alt, ps, etc. while it's making the noise.
Old Apr 12, 2007 | 06:29 PM
LxMan1's Avatar
LxMan1
No belt tensioner on a 77. Could be the alternator or PS pump.
Old Apr 13, 2007 | 10:19 AM
wintremute's Avatar
wintremute
Well, it's had an alternator replacement also. It has been making this sound for a long time, it's just getting worse lately. It used to just do it over 60 but it seems be doing it at lower speeds now. (I don't have a tach). Also, it seems worse after it has warmed up than when cold.
Old Apr 14, 2007 | 06:06 AM
HemiEater's Avatar
HemiEater
do the screwdriver thing...it will pinpoint it. and it makes it in neutral....??
Old Apr 14, 2007 | 10:52 PM
LxMan1's Avatar
LxMan1
Yes, carefully do the screwdriver check. Check the timing cover, it could be the chain slapping the cover.
Old Apr 15, 2007 | 12:10 AM
petes79f150's Avatar
petes79f150
Original timing chain with 240K? Man, you must be living right....
chamblizi
General Automotive Discussion
15
Jun 3, 2012 04:18 AM
Brad34
2004 - 2008 F150
Aug 21, 2010 12:55 PM
reecem13
26
Aug 1, 2007 11:03 PM
Bunyon's_Ox
Jan 10, 2007 04:58 PM
wintremute
May 10, 2006 01:44 PM
