Distributor vs. Doofus
Old Sep 19, 2002 | 08:00 AM
Digger1's Avatar
Digger1
OK, I know that I have done this before, but on my 76 460, I can't remove the distributor! I have the retainer removed and have even turned the engine over, but I can't even get it to turn. Any suggestions other than a 10lb. hammer?
Old Sep 19, 2002 | 11:15 AM
qtrmiler's Avatar
qtrmiler
Soak it for a day or two with some GOOD penetrating oil & hope for the best.
Old Sep 19, 2002 | 01:38 PM
Just Strokin's Avatar
Just Strokin
Find someone with a CO2 fire extinguisher and freeze it. Was one method that was used quite oftend on the old 272-292-312 Y block Fords.
Old Sep 19, 2002 | 11:47 PM
the law's Avatar
the law
I got mad and used a crowbar on both my '74 and '89 460's after they seemed stuck. This is sort of a last resort though.
The Law
1989 F-250 HD 4x4
460, C6, BW 13-56
Almost Stock
Old Sep 20, 2002 | 10:46 PM
airharley's Avatar
airharley
Sounds like the oil pump shaft is bound. Try to turn the motor backwards by hand. You should only need to turn it an 1/8 of a crank turn to get it out.
Old Sep 24, 2002 | 09:18 PM
phantom429's Avatar
phantom429
If you look into the history you will find a good thread on this subject. Basically you need to soak the distributor with penetrating oil for a couple of days. You also will have to work it with a large wrench back and forth, even if it just a wiggle. You can alto try hammering it with a brass drift to break it free. Be patient, it will come loose.
Nick from the frozen north
1974 F-250 4X4
soon to be 429
dana 60 front and rear
Old Sep 26, 2002 | 11:03 AM
laptopgeek's Avatar
laptopgeek
Digger1 ---
Heh heh heh.....I tought my distributor who was boss, yes I did. I jerked the oil pan off, ripped off the oil pump and rammed a long Craftsman 3/8" exension up in that hole I did and proceeded to pound the dayights out of the bottom of the distributor with a 12 pound sledge hammer. (Wasn't a scene I would suggest your young kids to witness.....)
Yessireebob --- out it came like a wet cat straight out of the creek! (I was going to replace it anyway with a Mallory unit
Good luck,
Old Sep 28, 2002 | 10:24 AM
phantom429's Avatar
phantom429
You big meenie. :P
1974 F-250 4X4
soon to be 429
Old Sep 28, 2002 | 08:45 PM
elliott's Avatar
elliott
Old Sep 29, 2002 | 03:00 AM
the law's Avatar
the law
Heck, I'd probably recommend even my crowbar prying method before that...
The Law
1989 F-250 HD 4x4
460, C6, BW 13-56, Sterling 10.25" (4.10:1), Dana 44 HD (4.09:1), twin K&N's, no muffler, stock lo-flo cat, Bosch Platinum Plugs (0.060") MSD 6A and TFI Blaster Coil
