1996 EFI 460 mods, help!
So far I have only tuned it up (including fuel filter), and said goodbye to the cat (OBDII didn't like that, but you can fool it into thinking the cat is still active).
Now for some questions for the seasoned EFI 460 guys:
On my '89 there where resticive horns in the intake, I don't see any on this '96. This truck is a CA model, does it have them?
I have read on this board that the CA '96-'97's are mass air. How do I tell if this truck is mass air?
If I change the timing set to a pre-72, what should I expect since this is an EFI 460? Will I still see a nice power bump or will the engine simply explode?
Will the mpg go into the toilet or get better?
Any input for mods on this truck greatly appreciated.
I would also recommend throwing that cat back on, as it cleans up something (benzene, maybe?) that is EXTREMELY cancerous. If you're that concerned with back pressure, try running just the cat with no muffler. Many of us here (including me) do that and have noticed increases in power and fuel economy at the expence of a little low-end torque, but you've probably already seen that after the removal of the cat. Also an after market cat can sometimes flow better than a high-perf muffler. Random's cats will out flow just about anything on the market.
The Law
1989 F-250 HD 4x4
460, C6, BW 13-56
Almost Stock
On my '89, I just tapped the air line into the exhaust pipe.
the law has a good point about the cat taking care of benzyne though. After reading his post I did some research and found what he said to be true.
http://webpages.charter.net/belzurkur/96_ford.jpg
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=4039&.jpg
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=474&.jpg
Why Buy new when you can build and tailor it cheaper?
F-350 4x4 ext cab Short Bed Green Monster, it is now Sporting a 300HP 715lb/ft Dyno rated 5.9L 12v Cummins diesel w/ NV4500 5spd and custom NP205 ford T-case w/ rear spicer 1410 yoke, Converted to Sterling 10.5 gears w/3.73 gears using the 41 spline pinion and 1410 U-Joints, Power-Lok equipt Dana 60 front, 33's on 16x8" Outlaw II's. (Used to have)205000 miles, Mass air 460 w/ performance heads and a E40d to 5spd conversion and Doug Thorleys. Old EFI 460 @10 MPG to the 12 V @ 23.2 MPG @ 75 MPH and loving it.
My other toy is a '69 CJ-5 354 Hemi 4 spd 4.88's 32x12.50 MThompsons w/ power-lok 44 rear.
(updated) F-350 4x4 ext cab Short Bed Green Monster, it is now Sporting a 300HP 715lb/ft Dyno rated 5.9L 12v Cummins diesel now w/ NV5600 6 spd and custom NP205 ford T-case w/ rear spicer 1410 yoke, 3.55 gears using the 41 spline pinion and 1410 U-Joints, Power-Lok equipt Dana 60 front and posi rear, 315/75's on 16x8" Outlaw II's. (Used to have)205000 miles, Mass air 460 w/ performance heads and a E40d to 5spd conversion and Doug Thorleys. Old EFI 460 @10 MPG to the 12 V @ 23.2 MPG @ 75 MPH and loving it.
