84 300 timing
Old Dec 12, 2003 | 12:22 AM
MontanaFord's Avatar
MontanaFord
84 300 timing
couple questions on timing my engine...
i read in a shop manual for my truck that the timing needs set at 12 degrees BTDC....what's the BTDC stand for? also...where is 12 deg. BTDC? the distributor i have has the ignition module on the distributor...
how do i do a rough-set on my timing?
MontanaFord
Old Dec 12, 2003 | 06:31 PM
scamardo's Avatar
scamardo
Before Top Dead Center.
I always timed mine at 10 deg. Climb under the truck or in the engine bay and use a wire brush on the vibration dampner to find the timing marks. Use something like "white-out" or something similar that you can view the marks with. Put a timing light on it, pull and plug the vacuum hose from the distributor to the carb and check your timing. Should be between 10-12 BTDC.
Old Dec 12, 2003 | 09:25 PM
paulfix's Avatar
paulfix
I set min to 14 btdc and I find it offers better power with a steadt idle. Sometimes the vibration damper can slip on the crank so it is worth your while to spend 5 mins to make sure that TDC is really TDC. You do this by removing spark plug #1 ( nearest to the front) and use something soft like a used spark plug lead andpoke it down the plug hole ( dont drop it in and lose it) and turn the engine over by hand using a wrench on the crank pulley bolt and feel the piston coming up the cylinder and as it reaches the top ( TDC) compare the marks on the damper . If the are aligned continue to check your timing with a timing light following the procedure in the manual
Old Dec 14, 2003 | 12:13 AM
fordeverpower's Avatar
fordeverpower
wait! The module is tfi and it doesn't matter. But there is a spout connecter that needs to be unplugged before you time the engine.
Old Dec 14, 2003 | 06:52 PM
MontanaFord
what's the spout connector? is it the plug that goes into the module?
MontanaFord
Old Dec 14, 2003 | 07:03 PM
fordeverpower
the spout connector is a plug that is attached to a wire or something. it should be located near the distributor and it unplugs. it is black and very small.
Old Dec 15, 2003 | 11:04 AM
sail2244's Avatar
sail2244
The spout connector is a yelow wire the connects to the TFI module on the side of the distributer. Don't pull on it too hard or you could strip the insullation off the wire. The wire goes into a shielded cable with 2 other wires and you can very easily strip the wire insulation and not be able to see it because it will be under some tape. This can cause the spout to short to shield which causes the engine to cut off.
Disconnect theis connector to set initial timing.
Pop's76
Feb 18, 2011 05:27 PM
MontanaFord
Sep 21, 2004 08:34 PM
MontanaFord
Sep 21, 2004 01:20 AM
MontanaFord
Aug 12, 2004 10:02 PM
MontanaFord
Dec 29, 2003 11:27 PM
