- D0VE -vs- C8VE heads
- valve seal replacement
- engine vibration on new rebuild
- Heat shields or other problems?
- ---------New 460ci LB for $500!!!!!!!!--------
- Getting the 460 in there.
- 460 size
- oil pan removal
- Need help setting valve adjustment
- stumbles after warm up
- 460's are pre fuel injection blocks the same as fuel injected blocks
- hemi heads
- 460 backfires 1996 motorhome
- What year 460 motors will work
- 460 mods/ideas
- 88 460 head swap
- 460 is fubared...
- EGR Tube
- 460 compression ratios
- SMOG pump - Need one.
- quick head question
- 79 F250
- Gear Drive or Double Roller
- 460efi fuel pressure
- firing order
- 460 build up questions??
- Not running hot enough?
- What is THIS worth???
- Bearing noise on 92 f-250 w/460 when cold
- ABS not working on 1992 f-250 4x4 w/460
