Gear Drive or Double Roller
Old Oct 15, 2003 | 08:04 PM
Duthlerfordparts's Avatar
Duthlerfordparts
I am planning on building up a 460 for my '77 F150 4X4. I want to build a Hemi Ram killer! I'd like to squeeze out about 400 hp. Anyway, here's the point: Would I be better off with a gear drive or a double roller timing chain. I like the noise of the gear drive, which is basically the whole point of using it. Cost is not a concern, I am just worried about a gear drive causing too much vibration, and possibly harming the engine for a daily driver. Should I leave the gear drive to the race cars, or can I play with it on the street?
Old Oct 15, 2003 | 08:24 PM
proeliator's Avatar
proeliator
You can get pretty much the accuracy of the gear with the roller without the negative harmonics caused by the gear set. I'd stick with the double roller.
Old Oct 15, 2003 | 11:03 PM
LxMan1's Avatar
LxMan1
I agree. The chain will absorb some of the engine harmonics and will last a long time. Edelbrock maked a good one for a fair price. Thats what I used in mine.
Jimmy
Old Oct 17, 2003 | 08:50 AM
Hired Gun's Avatar
Hired Gun
Gear drives are for diesels and low rpm or heavy loaded cam drive applications like sprint cars that drive the fuel pump and water pump off the cam. They are not for performance applications due to the transmission of crankshaft harmonics into the valvetrain. A belt is the best followed by a nice true roller chain drive.
Old Oct 17, 2003 | 08:53 AM
DanTana's Avatar
DanTana
If you want noise, put a GMC 6-71 blower on it then you could justify using a gear drive.
Old Oct 17, 2003 | 10:17 AM
LxMan1's Avatar
LxMan1
If it had a 6-71 blower on it, then it wouldn't need the geardrive for sound.
Old Nov 2, 2003 | 04:59 PM
Duthlerfordparts
Something I forgot to think about; does anyone know if the fuel pump eccentric will work with gear drive? I guess this is one more reason to go with the double roller!
The 6-71 blower crossed my mind more than once! Level heads prevail, though when I remember I have to drive the truck in the winter.
Old Nov 2, 2003 | 09:59 PM
ZRX61's Avatar
ZRX61
Apparently it does, but I'm running a Carter electric pump anyway so I left all that mech fuel pump stuff sat on the shelf
Old Nov 2, 2003 | 10:53 PM
headturnin65's Avatar
headturnin65
it works fine....
I'm running a gear drive, and before i went with an electric pump, I had an eccentric running a mechanical.
