460 mods/ideas
Old Oct 18, 2003 | 10:59 PM
mattri's Avatar
mattri
460 mods/ideas
New to the forum, first post. I have an 87 f-250 4x4 with the 460 (holly 4 not fi) zf 5spd and 10.25 rear. The truck runs well but soon I want to upgrade the carb and intake. I was thinking of a Weiand Stealth and a Holly Truck Avenger 770. Later I will be adding headers and eventually warming up the motor itself. Nothing extreme, minimum overbore, mild rv cam and a pocket port.
Question 1 Any comments or suggestions on the above set up?
Question 2 I live in Denver. I have used Heads by Paul in Englewood before but I recently visited Blue Oval Performance and was very impressed with Rob. Have any of you used him? Any comments or other machine shop reccomendations? Any help greatly appreciated.
Old Oct 19, 2003 | 01:18 AM
LxMan1's Avatar
LxMan1
I have always had good luck with Edelbrock Performer manifolds. They always seemed to make a bit more power than the Weiand's do. Holley now owns Weiand, I don't know if they have improved them any or not.
Jimmy
Old Oct 19, 2003 | 01:28 AM
mattri's Avatar
mattri
Thanks for the info. I just found out that Edelbrock makes their Performer intake for the 460 with the EGR (stupid emissions) and it's about $20 cheaper than the Holley. Like I said this is going in an F-250 so the low end torque is really important. Have you found the Edelbrock to perform better in the low or mid-range?
Old Oct 19, 2003 | 09:29 AM
georgedavila's Avatar
georgedavila
Up to 3000rpm the stock manifold is as good as any aftermarket piece. I've used both the Performer and Performer RPM on 460s and feel the RPM provides a crisper throttle due to the longer runners. The Performer is rated to 5500rpm, the RPM to 6500rpm, not a concern for you with a torque application. The Weiand Stealth is preferred by most running high rpm applications, but again, that doesn't apply to your application.
For plug & play ease, you can't beat the Edelbrock 750 carburetor.
I've them and Holley 750s on 460s, currently a Street Avenger 870, and simply put, Holleys do require tuning, especially at your altitude. You can also save some decent money buying one of the factory rebuilt Edelbrock 750s from Summit or one of the other aftermarket mail order houses.
Full headers will give you your best gain, with or without the other modifications, and especially if you upgrade the induction.
Old Oct 19, 2003 | 11:47 AM
mattri's Avatar
mattri
I hadn't really heard anything about the stockmanifold,I'm glad you brought that up. You said that the stock was good to 3000 rpm, how badly does it drop after that? How much would a port job help if any? Also, I've heard great things about Thorley headers. They have headers with a 3/8 or even a 1/2 flange, but man they're not cheap. Any experiance with those or other good headers? Thanks for the replies, I'm new to the 460, I was a straight six man for a long time.
Old Oct 19, 2003 | 12:14 PM
georgedavila
There's not much left after 3000rpm as the regular production (truck/car) 460 was designed for low/mid-4000rpm max.
Anything you do to the heads will help as they're the weak design point in the 385. Unless you plan to turn some high rpms, all I'd do is take off the smog bumps, clean up the casting marks in the ports and clean up the chambers. You're not after high rpms and want the low rpm intake velocity, so stay with stock sized valves.
I've used cheap Hedman Hedders and its a you get what you pay for situation. I have no experience with the Thorleys. I'm on my second set of L&L headers (sold the first set) and wouldn't use anything else on a truck 460. Others on this board will also support the L&Ls. Whatever brand you decide on, go with full-tube headers, not the tri-ys. All advertised gains from tri-ys are mostly from the new exhaust system that usually accompanies them.
Old Oct 19, 2003 | 04:46 PM
mattri's Avatar
mattri
George D thanks for the tip on the LandL's, I checked out their web page and they do look good. What's the flang thickness?
Old Oct 19, 2003 | 06:33 PM
georgedavila
I don't remember, but they're beefy and you won't have to ever worry about warpage or leaks. Here's a couple of images:
Old Oct 19, 2003 | 07:41 PM
mattri's Avatar
mattri
Those look plenty thick enough. What did you have them in? Do you live where you need to worry about emissions?
Old Oct 19, 2003 | 11:02 PM
kermmydog's Avatar
kermmydog
I have an 86 F250 4x4 460 with a C6 Tranny and 3:55 gears. I just started what you a thinking of. I installed an Edelbrock Perfomer with a Holley 4160 and a TD torque swirl 1" adapter, and installed two Summit turbo mufflers. I could not believe the difference, I also de-smoged. I'm now starting to fine tune the Holley, after a trip I have a starting place I plan on going with a two-stage power valve and one to two smaller jet sizes. A 600CFM is plenty for most all 460s unless you are going to build and engine that turns over 4500 rpm's. and most 460s don't like high RPM's. Remember with Holleys you don't have to worry about power valve blow-out because they built in protection starting in 1992. they work I tested it.
Old Oct 19, 2003 | 11:16 PM
bigsnag's Avatar
bigsnag
I still, personally, think the Weiand is the best manifold on the market (except in full out racing engines). A well circulated test named "BBF Intake Shootout" showed that the Stealth outperformed both the Performer and Performer RPM in BOTH torque and hp production. This test was done on a relatively mild 460.
Old Oct 20, 2003 | 06:27 AM
georgedavila
I agree the Stealth would be my first choice in intake manifolds, I just don't have the clearance to run one. I disagree on a 600 or 625cfm being the ideal carb for a stock or mild 460. I had a 625 Carter I used as a spare carb for years. When I'd put it on a 460, stock or modified, I always noticed a drop in performance from a 750 with no change in gas mileage.
mattri, I have a 460 in my '82 Bronco. I've had various 429/460s in it since 1986. No, it would never pass emissions.
http://www.angelfire.com/realm3/george_d/index.html
Old Oct 20, 2003 | 08:46 AM
bigsnag's Avatar
bigsnag
If your running a Performer RPM, then you have room for a Stealth. If you are running a regular Performer, then you should have room to run a Stealth with a 1 or 2 inch drop base on your air cleaner.
Old Oct 20, 2003 | 09:11 AM
georgedavila
I can't run a drop base air cleaner, it won't clear the Holley vacuum secondary spring container. Look at the firewall clearance behind my air cleaner. I sat a friend's Stealth w/Holley and air cleaner on it and no way would it fit.
Old Oct 20, 2003 | 11:30 AM
bigsnag's Avatar
bigsnag
How many inches across is your current air filter? 12? I'm not sayign it can definitely be done, but it looks like if you went to a 14" and a two inch drop it should clear both the firewall as it would be below the area sticking out and it should be big enough around to clear the spring container. Have you checked with http://www.ramairbox.com to look at their aluminum drop bases? They give the most clearance of any drop bases I've ever found. BTW, that's a sharp looking engine. What are your specifics?
