460 build up questions??
Old Oct 14, 2003 | 05:35 PM
Goodold71's Avatar
Goodold71
Question 460 build up questions??
I have a 429 out of a 72' LTD. I am putting different heads on it D2's are not so good I'm told. I am putting this in a 4x4.I would like to know if cast iron heads would be better than aluminum heads on a 4x4? If so then which heads should I get that would be easy to install roller rockers? I plan on mud bogging and the rpm's will be up there? I also plan on swapping in a 460 crank and rods or a stroker kit. Anyone who can help?
Old Oct 15, 2003 | 09:18 AM
LxMan1's Avatar
LxMan1
The Elelbrock heads should work nicely, as will the FRPP Cobra Jet heads. If you are going racing, then I would use the aluninum heads if the funds permit.
Jimmy
Old Oct 15, 2003 | 05:46 PM
mike460's Avatar
mike460
hey man, i would stick with either the edelbrock heads(funds permitting) or a set of cast iron heads, such as dove-c's or police interceptors(both of wich are set up from the factory with screw in studs. for a four by you'll want this motor to have lots of low end grunt. the cubic inches helps out a lot. keep the cam duration to around 220-224 @ .050. put roller rockers on it, and get a good intake for it, i recommend the delbrock performer rpm or the weiand stealth. put a 750 cfm carb on it and a good set of headers. keep the compression around 9.0 to 1. this out to get you some serious horsepower with awesome low end torque. good luck man
hope this helps
mike
CaptainJack_7
18
Mar 3, 2015 09:25 PM
93f250tn
Feb 23, 2013 01:54 AM
74crwcb429hibPS4spd
Apr 23, 2003 07:16 PM
4X4X460X76
Nov 13, 2002 07:16 PM
79bigblue
Oct 19, 2001 11:05 PM
