88 460 head swap
Old Oct 17, 2003 | 06:55 PM
hotrodmerc's Avatar
hotrodmerc
88 460 head swap
Can a set of early model heads such as 1972 or 1973 be used on a 1988 engine with F.I. ? I just want to swap the heads and use the F.I. intake, is this possible?
Old Oct 18, 2003 | 02:40 PM
Superdave's Avatar
Superdave
No.
Old Oct 18, 2003 | 02:52 PM
hotrodmerc's Avatar
hotrodmerc
Does the f.i. intake use a different port design?
Old Oct 20, 2003 | 02:12 AM
Superdave's Avatar
Superdave
Yes.
Old Oct 20, 2003 | 10:42 AM
alabamabuddog's Avatar
alabamabuddog
Hummmm such short answers?
Old Oct 22, 2003 | 12:42 AM
Superdave's Avatar
Superdave
Yes.
Brevity.
Old Oct 22, 2003 | 08:49 PM
shuttlevalve's Avatar
shuttlevalve
fuel injected 460s had its own head design with smaller valves. i think what you want is the 72cc DOVE heads or C8VE high compression heads. the 1972 and on are the smog heads low compression. The efi wont be able to compinsate with out using chips and a lot of fiddling around.
Old Oct 26, 2003 | 08:35 AM
hotrodmerc's Avatar
hotrodmerc
Question
What are the cc of the heads in 1988?
Old Oct 26, 2003 | 09:50 AM
MustangGT221's Avatar
MustangGT221
Moved to 460 big block forum.
Old Oct 26, 2003 | 09:56 AM
georgedavila's Avatar
georgedavila
C8, C9 and DO heads all had 75-78cc combustion chambers. They'll fit on any 429/460 block, the intake port surface angle is different on the EFI heads to accomdate the EFI intake manifold, which won't fit on the earlier heads without serious work.
Two Lane Black Top
Aug 4, 2013 10:45 PM
Floor-N-It
Jan 12, 2011 08:45 PM
Jimmie MORGAN
Mar 22, 2008 09:48 AM
uriah
May 18, 2007 08:58 PM
hybridf250
Feb 8, 2003 09:43 PM
