- Vacum Advance
- cylinder head question
- 390, 406, 410, 427, 428
- A 389?
- Rear main bearing seal on 390
- Why Fe
- 390 Build Recomendations
- .060 over 390 = 4.1 bore right?
- Rod Noise??
- Performance Distributors for a 390
- 390 carb question
- 330 hd engine won't fire
- Fuel pump.
- So how's everybody's truck running?
- FE446 exhaust material question..
- 360 FE vs. 351 windsor
- question about fe cylinder heads
- Why is it best to use delay port ?
- Help! I'm going nuts...
- different thermostat housing for 390?
- Stock Hp, Ft-lbs? 360
- New 390 stroker buildup...
- points or electronic?
- OK when did they start this!
- Make your own MSD advance bushings...
- 390 buildup on 5K
- FE446 new track times!
- 300 to FE 360 / 390
- Aftermarket ignition
- 360 to 460 swap
