360 FE vs. 351 windsor
Old Jan 29, 2005 | 11:44 AM
Huntersbo's Avatar
Huntersbo
In a scout 800 am I better off with a 360 or a 351?
considering both engines have a 9.5:1 compression, headers, 210 D , .500" valve lift, 600 cfm 4 barrel vacume secondaries, electronic ignition.
Old Jan 29, 2005 | 12:07 PM
gtex's Avatar
gtex
If you have to do a conversion to get either of those motors in there, then I'd probably go with the 351W. It should be cheaper to build and provide plenty of power for the Scout. Unless you're looking for a WOW factor of an FE motor, then look at one of the bigger FEs (390, 427, 428 etc)
Old Jan 29, 2005 | 12:16 PM
rusty70f100's Avatar
rusty70f100
If it's a stock 360 it's not 9.5. It's more like 7.8. Now if you built up a 390 like Greg said, that would be great.
Old Jan 29, 2005 | 01:45 PM
Ratsmoker's Avatar
Ratsmoker
The stock 360 would make more power with identical performance cams and headers as the stock windsor heads flow quite a bit less but as far as getting the engine into the scout I would choose the windsor. It will make good power and be lighter.
The 351W would be my choice.
Old Jan 29, 2005 | 07:49 PM
Huntersbo's Avatar
Huntersbo
how much is too much for a Scout at 3500 lbs do you guys think?
I think a 390 would be fun but is it too much for the street?
I will be using a T-19 granny with 33" tires and 3.55-3.73 gears.
I want ot give it very little gas and have it move quick because I do not want to have to open the secondaries during normal driving, I do not like 4 bangers because you have to scream them to get them out of your own way. A V8 you can have the deep sound at low revs but not annoy the neighbors by reving 5000 to go fast.
I want some thing that is bullet proof and will be strong for along time.
Old Jan 29, 2005 | 08:02 PM
rusty70f100
I think either, if built right, could serve you well. A mild 390 build will not be too much for the street. Gobs of low end torque available with the right cam. You might even look at building a 410 (360 / 390 block with 428 crank).
A 390 will weigh more, but with aluminum heads and intake it shouldn't be that bad at all. Also the FE will produce more torque, simply from the longer stroke and more cubic inches.
Plus, you'll get plenty of comments about having an FE in there!
In the end though, the choice is yours. I dont think you could go wrong either way.
Old Jan 29, 2005 | 08:14 PM
FERacing66's Avatar
FERacing66
Id put in a nicely built but mild 390FE that would outpower the 351 easily and the FE's are among Fords most relaible and durable engines. A stock 360 has 7:2:1 comperssion according to my chiltions manual so they are sorta weak in stock form.
Old Jan 30, 2005 | 12:10 PM
Huntersbo's Avatar
Huntersbo
And you guys say that it is not worth it to build up a 360, I think one would wake up nicely.
I like FEs more than others because most Bronco guys go 289, 302, 351, I want to do something different, not a FERAri vs. Muscle car bunch , but suprise people what an older engine can do because alot of people think new is better. I think that technology is BS
when I'm done building up this scout it will basically be a Bronco because of all ford Drivetrain and ENgine and mild change of body design, alot of people think new is better. I think that technology is BS simpley because it is complicated and is usually more fragile than old tech, I can not even figure uot how to adjust the jets on our 1990 Bronco 2, I just turn the idle up if it is too weak of a take off form 700 rpm. I think that the FE is the most simple v8 I can go and should go with out going flat head.
that is why
Old Jan 30, 2005 | 12:12 PM
Huntersbo's Avatar
Huntersbo
YOu are right a 390 would be simpler to build to what I want to an a 360 though.
Old Jan 30, 2005 | 12:17 PM
Huntersbo's Avatar
Huntersbo
Is it possible to get 400lbs of torque and only 250 hP OUT OF A 390 , mabe with a 194 D cam with a 108 lobe center.
Old Jan 30, 2005 | 12:28 PM
rusty70f100
Heh, you have no idea what a 390 is capable of, do you?
How's this:
1. 390 block, crank, .030" over (most usual overbore)
2. Edelbrock Performer RPM heads and intake
3. TRW / Speed Pro L2291F30 pistons, Fel-Pro .041" thick head gasket - 9.54:1 compression
4. Crane 343901 cam
5. Adjustable rocker setup - allows accurate lifter preload
6. Holley 600cfm carb
7. Headers - dual exhaust
The above build results in 368hp @ 5000rpm, 443ft-lbs @ 3500rpm, and 431ft-lbs @ 2000rpm. The torque curve is nice and flat.
Old Jan 30, 2005 | 04:57 PM
gamble71's Avatar
gamble71
sounds like you've already made your mind up. However I'd go with the 351. It weighs less, is just as durable, revs better, has more of an aftermarket following, etc,etc... Now I love FE's but unless you go 390 or bigger, the 351 is the better choice. Just my .02
Old Jan 30, 2005 | 06:29 PM
Huntersbo's Avatar
Huntersbo
what can a 351 do torque wise?
Old Jan 30, 2005 | 09:37 PM
gamble71's Avatar
gamble71
I'll have to go pull some of my old hotrod/carcraft mags out for exact #'s. I do know that 400-450 ft/lbs is very easy to obtain on pump gas and factory parts.
Old Jan 31, 2005 | 01:42 AM
Fordbronco69's Avatar
Fordbronco69
Infidel
Im not a real big 351 fan but....hes looking for a durable engine that will move him fast right? What engines are in nascars? Build up a 351 good and give her hell!
