One of my electric cut-out vlaves broke recently. I cannot find the orginal cut-out caps. I used a piece of what appears to be 1/4" lead plate to fabricate a cap (2.5" cut out cover). Is there any danger in running this way for a while? I need my truck to be in legal mode for a bit!
I doubt there's any danger. But if you want to add a little more weight to your truck you might call the government to see if they have any 1/4" spent plutonium or uranium plate they could let you have.
I was lucky to have the plate laying around. Lead is also very soft to drill through and it makes a great soft sealing surface....Just wish I cold find the original covers....I'm so disorganized :-(
one of your electric ones broke? what happend? i was thinkin of going with those so i could have it really quiet or really loud. have yo uhad any problems with them? other then this what brand are they?
1976 drag
these are McCord Power Plates. the actual valve broke off the rotating axle. The weld just gave up... I'm a little dissapointed. But, they may have experinced some extra stress when the motor mount came undone at the track wed.
