360 to 460 swap
Old Jan 26, 2005 | 07:24 PM
randylbarnes's Avatar
randylbarnes
360 to 460 swap
I am in the process of building a 460 to go into my 1970 f250 4x4. It currently has the stock 360 in it. I am building an early model 460 with a 71 block & DOVE heads. It was originally a 429 but had a bad crank so i took one out of a 76 lincoln 460 motor that I had in the garage. I have what I belive to be a 351 bellhousing with a casting number of D7TA-7505-AD and a flywheel from an FE engine that has 184 teeth on the ring gear and an 11 inch. I want to know what starter to use since the 460 flywheel is said to have 180 teeth. I also have a 460 heavy duty truck flywheel that I could use with a 180 tooth ring gear but am not sure what to do. In the future I plan on installing a Clark 280VOHD 5 speed overdrive tranny behind the 460.
Old Jan 27, 2005 | 07:20 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..
See you on the boards.
...MOVED.....
