Help! I'm going nuts...
Old Jan 28, 2005 | 10:01 PM
ScottJM's Avatar
ScottJM
Ok, I have a fairly new 390(12,000mi) in my truck been running great. Well I live in texas so summers are hot and I do alot of drivin so i was running 20w50 in it, well winter came so i switched to 10w30. There is a loud tap/tick coming from the driverside, you only here it when idling or if you let of the gas and coast down the street. It was extremely faint before but after the oil change it got horrible.
Old Jan 28, 2005 | 11:01 PM
longview1's Avatar
longview1
Banned
You could check your fuel pump. When i put in my new motor in the summer. A couple days later it sytarted tickin.....sounded like lifter tick. I grabbed a peice of rebar that was layin around , stuck one end in my ear and the other on various engine parts, then thought hmmm, Lets try the fuel pump. Sure enough, that was it. Quick 5 min fix. ( I had a spare fuel pump layin around).
ANyway, its worth a shot to check it out. Hope you find the problem.
Old Jan 29, 2005 | 07:22 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
If it's not the FP check out your valve train. Maybe a lifter gone bad or something similar. What rocker setup are you using?? G.
Old Jan 29, 2005 | 12:30 PM
ScottJM's Avatar
ScottJM
I'm using the stock rocker arm assemblies.
Old Jan 29, 2005 | 02:19 PM
Ratsmoker's Avatar
Ratsmoker
Check for header leaks too man. Sometimes chages in temperature will make the gaskets move around enough to blow.
twinzilla
Jun 19, 2014 07:42 AM
dracond
Apr 25, 2013 10:29 AM
JPs2003
28
Mar 5, 2012 10:15 AM
ford390gashog
Modular V8 (4.6L, 5.4L)
91
Dec 3, 2009 02:09 PM
Muley
New Member Introductions
Oct 25, 2004 04:54 PM
