- which vacuum advance port on 600 Edel carb
- silv-o-lite 1131's
- Mechanical temp gauge
- 390 cam recommendations
- '56 with a 74 390 3sp. Needs a 428 with a C6
- FE head identification
- 428 Engine swap
- Heya Scoot !! Question
- ford390gashog.......
- grinding when eccelerating
- 360 oil pump shaft????
- rear sump oil pan
- Not FE, but 815" of pretty...
- running unleaded gas in 390
- New carb or tweak this one?
- More rebuild questions
- builder in SE Valley of Phx AZ
- 390 stroker info?
- 410 runnig to warm?
- 410 running to warm?
- How to build my 390..
- pulled the engine now have a crank ?
- Well you guys went and did it now!!!
- 390 bolt kit?
- 352 motor mount
- changing spark pulgs
- Finally, some progress!
- FE identification help
- Oil Pickup location
- clutch issue
