silv-o-lite 1131's
Apparently they are split into two different categories, Hypereutectic and non-Hypereutectic.
The 10.1 comp. ratio is intended for the 390 and the 8.2 comp. ratio is intended for the 360.
With that being said, how would one tell which one they have will the are in the block with the heads bolted down?
I am referring to the 10.1 or 8.2 ratio not hyper or not.
Or, as fordever is referring to; is it one piston that can be installed into two differently stroked motors (i.e. 390 vs. 360) making the difference in comp. ratio?
Robert P.
Robert P.
See here:
http://www.kb-silvolite.com/spistons...iv=Ford&ci=390
And they're not really a 10.1 compression piston. Try more like 9.3. That's when used with the common Fel-Pro head gasket and 73cc chambers. KB-Silvolite uses the most optimistic methods for their stated compression.
How to tell?
I bought my Fairlane with a rebuilt 390, the guy said he put in Silvolite 1131's. What I did was borrow a bore scope from work and put it down the spark plug hole and determine the valve recess shape or dish size according to the previous chart from Beck Racing. Later I wound up taking the engine out and verified the pistons with the Silvolite logo and 1131 part number on the bottom side of the piston.
Originally Posted by I_Thnk_Ford
--Mike
The 360 pistons used in a 390 bump the compression up to what the higher HP car motors ran hence the dual application(as opposed to the dished out low compression truck 390 pistons).
I am assuming that the difference here is because of the difference in the crank stoke from the 390 and the 360?
Robert P.
Justins68ford
25
07-22-2011 10:27 AM
moonley
03-19-2007 09:07 AM
skonnie-mark
06-17-2005 01:08 PM
