FE head identification
Old Dec 20, 2005 | 08:27 PM
Ponyexpress's Avatar
Ponyexpress
I have picked up several FE heads and I was hoping someone could ID them. What motor they might have been installed. Are they special or any good? I have the part numbers and dates.
#1: C6AE-Y / SPEC or 8PEC
#2 C7AE-A / 6J28
#3 C1AE-6090A / 2L19
Thanks Tony
Old Dec 21, 2005 | 12:25 PM
tastyklair's Avatar
tastyklair
The C6AE heads are all from 1966-68 on 352,390,410,428 w/o AIR
The C6AE-d were for the same engines w/ AIR. However I can't find the Y behind any of the numbers. Are you sure it's not a K? Not that that would change the application.
The C7AE-a is for the same as above but started in 67.
The C1AE would be for a 61-63 352 and 390.
Old Dec 21, 2005 | 04:06 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
The C6AE-Y heads were a 66 head with 67.1-70.1 cc chambers and std size valves. The SPEC I'm not exactly sure the meaning but I've seen it on both heads and blocks as part of the casting number. These are medium riser heads withe the smaller "velocity" ports.
C7AE-A are the same size chambers (67.1-70.1) and valves (2.02-1.55) as the C6-Y's. These are 66-68 390 medium riser heads with thermactor tubes. 6J28 is the date code of 66/Sept/28th.
C1AE-A heads are 61-63 352/390 low riser heads with 71-74 cc chambers and the std size valves. 2L19 is the date code of 62/Nov/19th.
The C6-Y heads with the SPEC are kind of an odd head. I'll see if I can dig up some info on them application wise. I don't have much info on them off the top of my head but I'll check my books and see what they have.
G.
Old Dec 21, 2005 | 06:55 PM
ford5.8's Avatar
ford5.8
How do D2TE-A and C8AE-H compare to the rest? Anything special or different?
blisstruck
17
Oct 29, 2010 12:51 PM
wildwes
Jul 5, 2008 11:18 PM
nofortunateson
Nov 30, 2007 09:38 AM
jwrboss302
May 18, 2004 08:57 PM
Spudco
17
Feb 12, 2003 06:23 PM
