How to build my 390..
Well, I have a 390 with 1000 miles on it but whoever built the motor put to big of pistons in it and scored the block,bearings,etc..So im starting from scratch. It currently has dish pistons with closed chamber heads, could I go with flattops with those heads and still run pump gas? I have the factory 4v intake with a 650cfm edelbrock, will I gain much getting a aftermarket aluminum intake or do the oems flow good enough? And last but not least what if I put a 428 crank in,anyone know the best place to find one? Would it be worth it?
Thanks fellas
Thanks fellas
It sounds like one of those rebuilds where nothing was measured, just thrown together. Sad when that happens.
Anyway, we need more information before we can answer quesitons.
1. What are the head casting numbers? If you know exact head CC's, that would be better.
2. The OEM iron intakes do flow surprisingly well, but it's no Performer RPM. Probably somewhere between the Edelbrock Performer and the Performer RPM. The real advantage is in weight savings. The stock iron intakes weigh in the neighborhood of 80lbs. The aluminum ones weigh around 20. Big advantage there. However, some people have had issues with intake gaskets sealing with their aluminum intakes, so keep that in mind.
3. What are your priorities for the motor? Are you going to be hauling a grain wagon around, or hauling A$$ down the drag strip?
4. A longer stroke crank will increase displacement and in turn increase compression ratio and torque, all other things being equal. This will result in a slight decrease in gas mileage. I think the 390 crank is entirely adequate for any build, but ultimately the decision is yours. My general thinking is if I have a 390 crank I'll build up a 390, but I'm not going to go hunt down a 428 crank. But then again, if I had a 428 crank, then by all means... get it?
your haeds
Originally Posted by ford5.8
Tonight I got the casting # off my heads which is C8AE-H.. I did a search and it came up as 68 427-428ci heads!!! Does anyone know anything about these? Are they higher flowing then a standard 390 head?
Also how can I tell if their GT heads?
Heres the casting # site I was going by http://www.fomogo.com/info/cn/
Fellenz
23
12-08-2014 04:51 PM
460man
15
11-11-2005 12:38 PM
bshackelford711
27
06-07-2005 01:27 PM
67 428 Fairlane Ranchero
06-14-2004 06:42 PM
