390 cam recommendations
Old Dec 21, 2005 | 02:00 PM
powderspecial600_98's Avatar
powderspecial600_98
I am currently in the process of removing the engine from my 1974 Ford F-100 w/ 390 to repair the rear seal. As long as I have the engine out I plan on making some minor modifications/upgrades to it. I would like to replace the cam with a more of a performance cam. Currently I have a edelbrock performer 750cfm carb, performer intake, headers, and dual exhaust. I was thinking about the edelbrock performer plus cam as an option, but not sure. I don't really want to replace the valve springs as new heads were just installed a couple of years ago. Basically, what I am looking for is a cam that will work good with my current setup without having to change my springs. Any recommendations appreciated. Thanks
Old Dec 21, 2005 | 02:30 PM
rusty70f100's Avatar
rusty70f100
Those truck motors had low compression, especially if a Fel-Pro head gasket was used.
I recommend the Crane 343971. If you pull the heads and put a good head gasket on, like the .020" thick Mr. Gasket, you'll get your factory compression ratio back. Then I recommend the Crane 343901. The 901 might be pushing it a bit with those valve springs though.
Then you've got the whole issue of the non-adjustable valvetrain. Be sure to check lifter preload if you get a new cam.
If you really wanted to do it up right, you could get higher compression pistons and the whole works, but that would cost $$$.
Old Dec 21, 2005 | 02:48 PM
powderspecial600_98
Sure would like to upgrade the whole works, but you are right that is expensive.
Old Dec 21, 2005 | 04:27 PM
powderspecial600_98
What are the thought of the high energy series from comp cams?
Old Jan 9, 2006 | 09:27 PM
dj53's Avatar
dj53
I just fired my 390 top end rebuild and wow do I love the lope and sound of my Comp cam Summit #cca-33-224-3. She really ,really sounds good boy and It has just enough lope to make someone ask what's she got!!! yet enough vacume to run my power brakes. if ya really want I can send ya a sound bit as I also just added headers and new exhaust into new 40 series flows and turn downs!!! DJ
Old Jan 9, 2006 | 11:21 PM
powderspecial600_98
Yes that would be great, I would love to hear what it sounds like. I just bought the 268H from summit. I am in the process of installing it and completing my rebuild. Do you have the flat top pistons or are you running the stock ones? Whats it got for power? Any other add ons or performance mods besides the headers?
Old Jan 10, 2006 | 11:15 AM
dj53's Avatar
dj53
Just all new rods and springs,lifters. I ported and polished the heads my self so I am not really sure as to the gain as a professional job may produce more/?? DJ
Old Jan 11, 2006 | 01:41 AM
73fordf-100's Avatar
73fordf-100
Hey DJ53 I would really like to hear a sound byte of your motor with that 268H cam. I had order that cam over at Auto Zone and I was about to put it in when I had talk to a guy who had installed a Comp cam and he told me it went flat it the first 5 minutes of the engine break-in. So I started reseaching Comp Cams on the internet and had found several post about Comp Cams and lobes going flat. Hell I was at a loss so I returned it and put the stock cam back in.
This is a new but only a temporary motor for the winter while I build something with higher horsepower. I too am running headers, 3" pipe and 40 series flowmasters. I have an old elelbrock streetmaster manifold with a new edel 1406. I am looking for the lope sound you were talking about. If the 268H has got it and I dont have to change anything else I want it.
Send me a sound byte please.
Thanks
Old Jan 11, 2006 | 10:52 AM
dj53's Avatar
dj53
Well we just did about 50 minutes of break in last night and I hope no worn lobes. although I did hear that as well about the lobes!!. maybe not enough experience here to heed the warning and go with something else.Immediatly after the first start we went to about 1500-1700 and let her run a bit maybe 10 mins but I had to shut her down quick as i lost oil pressure, why?? well old dumnb azz me forgot to put the gasket between the pump and the motor in the build.so I replaced it anyway with a high volume pump. by the way does anyone know how much oil pressure these high volume put out as my oil pressure gauge says 100lbs. anyway I really tried to protect that cam in breakin.
J Hodges
20
Jun 17, 2017 10:40 PM
dzjammer
Mar 31, 2009 07:14 PM
fordfan28
May 20, 2007 09:31 PM
powderspecial600_98
26
Aug 10, 2004 11:17 PM
phaffy12
Jun 8, 2001 09:10 AM
