- Pulled an Explorer out of a swamp today
- Update
- Another Exhaust Question...
- alt only putting out 11 volts intruck
- filling coolant right now dont know what to do with degas
- limited slip
- Gear ratio advice
- two questions one viedo
- oh you LOUSY piece of @##$%%$#!!!!!!!!
- Rear fuel tank broken? air in lines?
- fuel/water separator question
- pump adjustment
- installing 6.9l injectors on a 7.3l??
- quick question
- What is it?
- Gear oil weight for Dana 70
- muti meter battery test
- charging system
- would you consider buying a 7.3 truck with "blown head gaskets"?
- Well I'll be damned
- Did Ford ever build a 1 ton standard cab short box?
- bb injctors on a na 6.9
- Helping a friend......getting frustrated
- heres the capacities list for our trucks....
- holy hell, truck is LOUD!
- flushing the junk out
- hard to start
- Welders: The rod is + and the clamp is -, right?
- 1993 F250 Tach/OD problem
- Apparently, Diesels don't run on gasoline?
