- oil leak but don't know what is leaking
- Young mechanic in need of elders wisdom.
- 1993 7.3L IDI losing prime
- How to lift off a crew cab without destroying it
- looking for info
- To swap or not to swap....woes of a poor gutless IDI Turbo Diesel
- Finding a flexplate
- loud clunk
- Power Steering Gear Failure?
- Different use for a IDI
- Viscous fan on a 7.3 IDI
- Throttle Position Sensor function?
- Buying parts for an upcoming head gasket job. Anything I missed?
- piston ring set
- 7.3 IDI Timing marks
- Well its fixed
- 6.9/7.3 Hydraulic valve lifter internals (pics)
- Loss of power at WOT
- How much amperage should PCM & Radio memory draw when off?
- Radiator
- What size fitting for supply line on injection pump
- 1990 banks install questions
- E40d help
- 6.9 ATS turbo
- 6.9 rasing rpms NEED HELP
- 6.0L Turbo on a 6.9 IDI
- E40d no forward or reverse
- trying to find the correct belts
- 85 6.9 diesel ç6 work on a 89 7.3 Diesel??
- Worked her a little today
