- Just bought a 7.3 IDI. Questions/Details
- Turnin 8' service body 93 F250 to An enclosed 9 footer PIC Heavy
- using heat on glow plugs
- new batteries dead/ Short
- Heads Up RECALL 93 F250 7.3 IDI
- New guy!
- Pigtail? Harness? Connector?
- lifter valley drain bolt or hold down
- Anybody near Denver need a ZF5?
- Can I pull a 7.3IDIT with ZF5 attached?
- gerator to alternator swap???
- Another air intrusion thread after replacing leaking fuel tank
- Signs of a dying pump?
- Keeper pins for rear spindle lock nut?
- First truck. Looking at an IDI....
- Ignition Key wont turn off
- How much these would cost in U.S.A
- 1990 idi
- 1991 F350 "D5N" axle code???????
- starting issue
- Found and IDI Injector that has no Identification Stamp
- What is this plugged port, and why would someone gob it with JB weld?
- Worth a darn?
- coolant leaking through cylinder walls
- How to identify # of axle splines?
- 1987 extndacab 4 x 6 --bringing back to life
- fuel tank
- Got new intake and catch can installed.
- Blow it in place.....
- Roof center console?
