- Keep it or part it?
- Need more power
- Soupbowl
- Gear Vendors vs US Gear o/d's
- Engine Heat light wont turn off
- Part#'s Premixed antifreeze
- 1991 7.3 starts but won't run !
- starter won't engage
- Ram Air Ideas
- Block heater location
- 2 different drive-belt tensioners??
- Injection Pump
- upgrade?
- Drive belt tensioner -92 vs. -93 ??
- How much pulling power?
- Gears
- Vibrations
- After market Power Steering Pump
- Pin assembly
- 89 f-350 w/cummins diesel
- Glow Plug wiring harness
- turbo noise
- steering column swap?
- air leak?
- Oil leak / opinions
- need advise on a diesel project
- Why is this called "pre-powerstroke"?
- EVP sensor location ?
- Low heat Problem
- dana and axel code on door
