- zf5 bellhousing switchover
- E4od
- Labor Time?
- Which Glow Plug to use?
- Where to find a wiring harness?
- bad injector?bad pump?other?
- fast idle for a pre 94 idi with turbo
- Value of old parts truck? Anyone parted one out? 1984 6.9 reg cab F250
- Pyro test??
- hx35 turbo ford!
- Heater whoas
- 7.3 in a ranger
- motor is stronger when cold!?
- C6 Woes
- Very few starts cold/no start hot
- Speedo needle bounce on 94 F350
- Pump timing spec for turbo IDI
- 7.3idi zf5 borg 1356
- Tired OEM voltmeter in cluster
- so how bad are they supposed to smoke?
- Wacky Tachometer
- Filler Pipe??
- Whats the most weight I can pull?
- zf 5 speed
- 1990 Ford F350 electrical problem?
- Dam truck won't start this mornin!
- 88 f350 brakes question
- Transfer case shifter broke!!
- Fuel Filter Dash Light
- Exhaust for F350
