- does anybody here go to this rally
- idijohns truck is famous look here
- What front shocks do you recomend
- stupid, stupid mistake
- Fuel filter/Water separator
- E4OD MLPS truck starts in all gears
- VRV Valve Swap Help
- Replaced cooling system and still overheating...
- fuel tanks only holds 13 gallons
- this has to be the dumbest thing ive ever seen
- Mounting of Jack in Engine compartment...
- Testing IP and injectors?
- Paint beginning
- ZF-5 Trans fluid: is hydraulic okay?
- not bad
- will this compression tester do the trick?
- One or two bad batteries?
- front parking lights not working
- 94 TD Tranny squeek
- White smoke at start up
- closed loop system
- ebay ats turbo. for sale.
- methanol injection
- Cam sensor
- what in the world is this for?
- Tach Question 94 IDI Turob
- Stalling when coming off idle
- Hard to start
- Fuel supply issue...
- Slow shutdown
