- 5speed swap question
- Air intake idea
- Timing marks for my IP...
- Head Gasket
- EGT temp question
- What's a flexplate adapter?
- Computer Problems
- Oh how sweet it is....but still kinda dangerous!!!
- Eary model 90's era turbo for 6.9 IDI 1986 F250
- '88 f250
- Did I fry my controler?
- Clutch safety switch?
- no oil pressure
- Rebuild or replace??
- Hydroboost to Master Cylinder Pushrod w/Spring & Retainer
- Fuel Leak
- Adding a limited slip to 10.25
- if anyone needs parts for a 6.9
- I'm a moran
- 1990 ford with turbo
- Worked on my ZF 5 swap tonight
- E4OD headaches!: Part II
- injector help needed
- I finally got my turbo installed
- Injector pump?
- it was a bad starter ..
- no start without a little ether
- engine help!
- e4od question
- E4OD swap to T19 or ZF5
