- Where does the TPS get voltage from?
- so I drove 10 miles with the brake on...
- Truck just cut off and wont start?!?!?!?!
- time for some maintenance
- Here's how I spent my night
- 7.3 IDI AT troubles
- Wrong oil cooler O-rings?
- Ticking through the intake
- 4 Inch Exhaust Build Plan
- Antifreeze leak somewhere
- Where to buy IP/Injectors?
- block casting number id
- IP and injector P/N's?
- Base Line Dyno run on the PRE-STROKE
- Need piston dimension
- different cab idea/question
- Quick question d60
- new injectors
- Engine and Turbo for sale
- 91 7.3 Banks Sidewinder turbo Down pipe need to make one
- no idle/stall
- Starter Solenoid on my Glow PLugs
- High EGT's, low power, lots of smoke, raw diesel smell
- Water Pump??
- Cold start video of my daily driver
- Flashing Rear abs light?
- voltage regulator or altnator
- Check this beauty out!
- Afraid truck wont start in the colder weather.
- New retrun line leaking on #1 injector
