- 6.9 head gaskets
- 6.9 IDI Gas engine swap
- F250 1989 7.3 IDI
- Cheap IDI in decent shape for the price of scrap metal
- Just need copper washers
- electrical problems
- Oil Drain Plug Info
- '86 6.9 tach
- 1990 F-250 7.3 IDI Belt Routing
- What's the biggest tire I can use?
- Fuel tank sending unit lock ring
- custom fuel shutoff solenoid
- block heater won't come out
- F-Super Duty VSS removal?
- 7.3 idi Glow Plugs leaving me stranded!
- Glow plug woes
- Fuel Screw and MPG. Any information?
- 86 F250 6.9L Wont run
- 1985 F-250 6.9 diesel Glow plugs or injectors?
- Oil Hemorrhage
- Injection pump timing no-no's
- Fuel Filter Housing
- Intake manifold?Cracked head?
- Newish lift pump pressure issues! Multi-layered questions...
- No power!
- Looking for a us gear dual range or similar
- the dreaded OD light flashing ( again )
- Should I buy it?
- Hydroboost line routing
- bubbling in coolant overflow reservoir, and not sucking coolant back to radiator
