limited slip
Old Jun 12, 2010 | 04:14 PM
gumper 123's Avatar
gumper 123
limited slip
My 94 the limited slip does not work, how hard is it to fix
Old Jun 12, 2010 | 04:33 PM
LCAM-01XA's Avatar
LCAM-01XA
Read this, should give you a pretty good idea of what's involved:
Sterling 10.25 Trac lock rebuild - Fourdoorbronco forums
Old Jun 12, 2010 | 06:11 PM
gumper 123's Avatar
gumper 123
Thanks good info
Old Jun 12, 2010 | 09:10 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I love the last picture!
Old Jun 13, 2010 | 12:40 AM
ManicMike's Avatar
ManicMike
Isn't the clutch packs the same as a ford 8.8? I have a spare rebuild kit for my mustang and I know my trucks LS could use a rebuild.
Old Jun 13, 2010 | 07:00 AM
my1strealtruck's Avatar
my1strealtruck
Red face
How do I tell if my 94 350 10.25 is LS?
Old Jun 13, 2010 | 07:07 AM
Lazy K's Avatar
Lazy K
Ford Axle Code Chart .: Articles Compare the axle code on the door sticker to this chart.
Old Jun 13, 2010 | 01:25 PM
LCAM-01XA's Avatar
LCAM-01XA
Similar style yes, but much larger than the 8.8 stuff, also there's no S-Spring but a pair of belleville washers instead. So no, you can't use the Mustang parts in your truck, unless said truck was an F150 with a 8.8 rear.
Old Jun 13, 2010 | 01:41 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
and if your not sure if the rear is stock or not;
jack up both wheels,chock the front tires,put it in N, and spin a tire.if they spin the same direction,your LS.if they spin opposite,its open.
Old Jun 13, 2010 | 08:10 PM
ManicMike's Avatar
ManicMike
Ah ok. Darnit lol
