two questions one viedo
Old Jun 12, 2010 | 02:26 PM
joe f350's Avatar
joe f350
YouTube - how do i use this thing
Old Jun 12, 2010 | 03:27 PM
rlwilson2's Avatar
rlwilson2
12v post is your battery +
Switch could be your radio (one will be always on for clock and memory on will be switched on)
Illumination will be any thing on the dash that lights up when lights are on...
Old Jun 13, 2010 | 12:51 AM
peruses's Avatar
peruses
looks liek you want the black and red probes in the holes that are the same color
if I'm seeing right in that tiny video the part of the dial to the top is for reading resistance and the part to the right of that should be DC voltage. you'll want the 20 volt setting for your charging system tests
Old Jun 13, 2010 | 01:20 AM
joe f350's Avatar
joe f350
thank u u can click on it to make it bigger
Old Jun 13, 2010 | 08:05 AM
Otahyoni's Avatar
Otahyoni
The ~ means AC, Joe. The solid line above the dashed line means DC. So to test volts, you'd want DC 20.
Also, on the top portion of the dail from the o))) below the "horseshoe shaped symbol" (Ohms) to the 20M is what you use to test resistance. The o))) is the continuity setting, which makes a beep when there is very little resistance.
NOTE: ALWAYS disconnect power source (battery) of item being tested when testing ohms!
VONxRUBENxLA
Oct 9, 2011 08:12 PM
Kwikkordead
21
Jan 18, 2011 07:38 AM
OutlawNomad
Mar 19, 2010 04:15 PM
jimbo beam
General Automotive Discussion
Jan 28, 2009 08:44 PM
PowerstrokeJunkie
21
Apr 21, 2008 06:27 PM
