- changing seats
- 84 6.9 idi - 2 broken head bolts
- Ford / Navistar Stanadyne IP Model #'s w/HP Ratings - Complete IDI Tuning Info
- 6.9 injection pump
- 3 5/16th bolts holding IP to timing gear
- Doing Gear Swap. Need Info ASAP
- ???RPM'S???
- Truck pulls
- a classic case of cardone
- how about powerstroke
- Got me a ZF5!!!!
- brownie problems
- running badly and blowing a fuse
- Axle code?
- Lift pump replacement and some cussn'
- Trans temp sender install on E4OD
- Timing off = white smoke?
- help! starting problems!
- My "new" water pump
- Anyone running an autometer tach?
- waste gate adjustment
- Vacuum question
- Where to buy a rear drive shaft
- Skid Plates
- MAJOR oil in coolant
- Inside diameter of factory turbo intake?
- 4x4
- VERY IMPRESSED
- IP number question
- PTO for T-19
