- Question is should I even start this project?
- Rear tank removal an fuel sending unit ?
- 7.3's running Hottt
- two questions
- Cummins gets better MPG right compared to 7.3
- 6.9 engine mounts replacement
- Open Stacks in the rain
- Which is more Maintenance friendly, Mpg the Cummins or 7.3
- Glow plug switch
- Tach question on a 6.9L
- Canada Trucks - what did Ford change?
- 7.3 turbo looses prime
- Bearing Wear Question
- IP Houshing switchout.
- 1989 F-350 Duelly EXTND Cab $2900
- Have the interior out any suggestions?
- Possible speed limiter on IDI?
- diesel ?
- new injectors!!! =)
- help engine miss and white smoke
- fixed the return lines
- Help !! Overheating...
- Need 2 7.3 engines
- 1989 IDI or 1999 PS? 5-spd + or -?
- 1990 7.3 starting problems
- Cheap mixed fuel
- Does turning up IP improve part throttle accel ?
- Fordson1
- Auto transmission Help!
- advance piston adjustment question
