- old 10.25 vs new 10.25
- Return Lines Again!!!
- Need some advice
- Location of sensors?
- 7.3 IDI turbo hard to start
- Troubleshooting a Persistently Low Temp Indication
- Does it exist for DRW
- Howdy, and some idi challenges
- starting with bad ring gear
- "New" '94 F350 IDIT - Grocery list of problems
- 1988 7.3idi died in driveway......
- Help w glow plug controller issue
- fuel injector flow pump adjustment
- 2-inch Body Lift Recommendation
- E4OD issue, lockup failing?
- Clutch cable broken
- e4od tach sensor,
- 89 F350 unknown wires
- Oil Cooler Gasket/O-Ring Change E-350
- Thinking about getting a 6.9
- Oil cooler leak
- cold start problems
- Aftermarket parts (napa u joints in particular)
- $550 IP timing, requires removing the front engine cover
- parking brake and abs lights
- fuel pressure and volume
- Possible turbo build
- Tach cutting out
- cam install question
- Fuel filler neck or vent valve?
