- Leaking oil not sure what I'm looking at
- Registration Fee Survay
- What does it mean when I shift (manual) into 2nd gear and it sounds like high rpm?
- 94 7.3l IDIT Crossover Pipe Between Exhaust Manifolds
- Starter whirl
- Fuse block question
- IDI blue smoke
- 94 non turbo 7.3 idi no start
- round pin connector diagram?
- No fuel pressure for 1985 ford f350 dually 7.3 liter diesel
- Considering an IDI, Hauling Capability???
- Had a Fubar with the '83
- Return line elbow size
- Glow plug connector
- 7.3L IDI very stubborn air intrusion problem
- Truck dies after switching to rear tank?
- Brake questions
- 6.9 IDI Podunk retired ambulance
- 1994 speedometer questions
- Why is my clutch not working right?!?!
- 7.3 idi front crani seal or oil pan gasket?
- Is this the right scanner to check my E40D transmission overdrive light?
- 93 7.3l idi smoke
- Cold ?, one runs rough one runs like new.
- New to diesels
- Strange Problem at Cold Start
- Can my cruise control work again?
- Help!! 7.3 IDI non turbo
- My idi doesn't like to start unless I plug block heater in for long time
