- Extreme smoking and misfire
- Eng. & Tranny
- Changing Clutch
- What do yall think
- rebuilding my 7.3 idi
- E4OD weight
- What's this thing on my rear-end?
- rear brakes keep locking up
- Pedal assembly malfunction
- Steering
- Fuel System identification (IP and Injectors, 6.9/7.3/7.3Turbo)
- Types of oil
- Rear gear change?
- Bad IP Symptoms
- 92 7.3 idi wont start after it has been driven
- engine swap
- zf 5 ??
- '91 F350 4X4 7.3L Engine/Powertrain Swap?
- What to look for??
- 7.3 rockers in a 6.9????
- engine sputering with white smoke?
- a/c vac pump only draws down to 26mm hg-is this enough?
- Transmission/Axle for towing?
- Engine Temp???
- How bad is old diesel?
- Power steering
- Need glow plugs @ 80-90 degrees?
- So I'm looking at tires...what do you guys think
- almost a disaster
- Transmission swap
