- 93 idi factory turbo 7.3 diesel
- Odd oil pressure fluctuation??
- dump kit
- ZF 5 speed transmission won't shift into reverse
- master cylinder trouble
- Turbo Boost?
- What will fit??
- More valve trouble? Maybe
- the 88 diesel and the starting circuit
- Diesel thats been sitting for years....
- New 1992 F250 with Banks Sidewinder question
- 94 ford f-250 turbo diesel
- Code 22 MAP/BARO sensor out of range
- 10.25 ring gear bolt stripped
- 6.9L Fix or replace
- Changing Heater Core
- t-18 on a 7.3T?
- i think i need a rebuilt trans zf S542
- 86' 6.9 Injector Pump swap into a 89 7.3 IDI
- pump up the power
- Super LOUD after injector pump install??
- Steering problems
- more fuel pump ?s
- white smoke
- Suspension Dilema
- How do I figure out what I bought?
- Common problem or not, PS leak?
- ip adjustments
- Fuel pump ?'s
- Testing an Injection Pump
