- DO we have top end oil ?
- what did ford change on the 7.3 idi turbo?
- what temp should I use the block heater?
- easy start w/out block heater
- new to diesels 94 f350 7.3
- Fuel Supply pump help
- finally figured out my problem
- where to find a cheep turbo
- Mileage Question
- How difficult to install turbo unit?
- Power Steering, Hard Brakes only at long idle
- Broke My Window and install question
- How much limited slip additive?
- riding rough?
- 91 F350 7.3l E4OD trouble
- Cooling system
- just installed ats turbo
- IP leaking problems
- 2 problems
- Powerstroke Exhaust
- stacks and injectors how much power?
- Stuck glow plugs
- What is the best year of the Ford IDI?
- Bailout
- Fuel system parts question...
- 7.3l w/o turbo Replace 4x2, E4OD with C6
- Turbo Guys
- where can find a pinion yoke
- Broken Glow Plug Thoughts!!
- Fuel Tank Return?????
