- newb question but i am stumped
- 2nd gear
- Correct injectors for a 6.9L turbo
- water in fuel light won't go out
- Changing the tank selector valve
- Cooling System
- 1987 F250 7.3L with 2x4
- When to change injector pump.
- need help !
- Replace 6.9L with 7.3L Power Stroke
- all warmed up and won't start
- Oil Cooler Swap Out
- 1986 6.9L Overheating
- '93 F250 4wd/auto trans problems
- leaky head
- Ignition switch assembly on 86 pickup
- Clutch bleeding.... why can't I get it right???
- F350 Sputtering
- 6.9 Electrical Blues
- rearend bounces
- Glow plug won't come out of hole after unscrewing; 7.3l
- Wait to start Light
- Where to find a used turbo?
- tips on turbo install
- Back on the road.
- Rebuilt injectors- now I get it!
- ok whats it worth?
- Timing 7.3's with the pulse method
- Fuse box woes!!!
- banks turbo downpipe
