- after market oil pressure gauge
- 7.3 idi Oil pressure
- body lift for turbo install?
- newly installed e4od gear engagement problem how to get codes?
- weird electrical problem
- Disassemble a Planetary Reduction Starter? 1983 6.9 F250
- 1993 ford f350 changed fuel filter now keeps shutting off!
- glow plugs don't work
- Body parts compatibility.
- Cost of fuel?
- What's a D-60 front axle worth?
- truck don't start
- factory turbo setup value
- 94 F250 Brake Light and Hard Pedal
- Turbo 7.3 to 6.9 block?
- Checking Block Heater..?
- 94 IDI Turbo, fuel leak on filter housing
- diesel wont start
- Many Fuel Issue
- Any luck using these glow plugs??
- 93 f250 schematic for multiswitch/brake/OD
- oiil leak
- Heater not blowing much air
- Bogging down, broke since June
- Upcoming Timing Job; Need suggestions.
- might buy a 1986 f350 turbo diesel
- Hydrolock?
- 6.9 IDI Exhaust
- Manual and GP contoller?
- 2nd opinion on fuel pump needed
