- banks turbo questions
- What besides glo plugs and controler could it be?
- My build thread
- My time has come at last. Injection pump
- oil leaking at the snail on 070 ats
- Starting Without Ignition Switch
- 1990 F350 7.3 electric fuel pump conversion
- hard starting when hot
- difference between injector posistion between 6.9/7.3
- Seeking Paid Assistance
- leaking return lines or cracked caps?
- Quick 4x4 conversion
- E40D Transmission Issues
- 1987 e 350 diesel
- Higher capacity differential covers worth the money?
- Brake Fade-will hydroboost help?
- Hard starting 6.9-Help, please.
- Interior Colors
- return line fitting between power steering pump and new gear box leaks.
- Mystery axle?
- Vacumn pump
- AC not working when I put new belt on...
- '87 Transmission swap
- I'm an IDI man forever now...
- ats turbo sucked the filter into turbo blades
- A few questions, 460 to 6.9 IDI change
- Clutch suggestions
- dumb question..?? Where's my voltage regulator - 1994 F250 IDI with factory turbo
- ats install still questions please assist
